why LINQ beats SQL
reference :
https://www.linqpad.net/WhyLINQBeatsSQL.aspx
SQL is a very old language—invented in 1974. Since then it's been extended endlessly, but never redesigned. This has made the language messy. You might have become so accustomed to this that you can't see anything wrong!
-Write a simple query that retrieves customers as follows:
SELECT UPPER(Name)
FROM Customer
WHERE Name LIKE 'A%'
ORDER BY Name
That doesn't look too bad, right? But now suppose these results are feeding a web page, and we want to retrieve just rows 21-30. Suddenly, you need a subquery:
SELECT UPPER(Name) FROM
   SELECT *, RN = row_number()
   OVER (ORDER BY Name)
   FROM Customer
) A
WHERE RN BETWEEN 21 AND 30
ORDER BY Name
Not only is this complicated and messy, but it violates the DRY principle (Don't Repeat Yourself). Here's same query in LINQ. The gain in simplicity is clear:
var query =
   from c in db.Customers
   where c.Name.StartsWith ("A")
   orderby c.Name
   select c.Name.ToUpper();
var thirdPage = query.Skip(20).Take(10);
