https://blogs.msdn.microsoft.com/nicktrog/2016/02/11/configuring-visual-studio-code-for-php-development/
ftp-simple
the only with support Remote directory open to workspace
https://marketplace.visualstudio.com/items?itemName=humy2833.ftp-simple
tip : at output window choose ftp-simple to see the transactions!
- : doesnt compare the filedate
ftp-sync
https://marketplace.visualstudio.com/items?itemName=lukasz-wronski.ftp-sync
use Ctrl+Shift+P, write : ext install ftp-sync then
use again Ctrl+Shift+P type : ftp
use:
ftp-sync: Init
to setup the plugin
dont forget to set "uploadOnSave": true!
ftp-simple
ftp-sync
use:
ftp-sync: Init
to setup the plugin
