reference :
http://stackoverflow.com/a/8889012
http://commonsware.com/cwac
http://www.androiddesignpatterns.com/2012/05/correctly-managing-your-sqlite-database.html
http://www.androiddesignpatterns.com/2012/07/understanding-loadermanager.html
AndroidManifest.xml
//at MANIFEST
<uses-permission android:name="android.permission.WRITE_INTERNAL_STORAGE" />
<uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE" />
<application
android:name=".Dynomite"
android:allowBackup="true"
android:icon="@drawable/ic_launcher"
android:label="@string/app_name"
android:theme="@style/AppTheme" >
Dynomite.java
public class Dynomite extends Application {
private static SQLiteDatabase database = null;
private static SQLiteHelper dbHelper = null;
public void onCreate() {
super.onCreate();
// method to get the sqlite db instance
public SQLiteDatabase getSQLiteInstance() {
if (database == null) {
dbHelper = new SQLiteHelper(this.getApplicationContext());
database = dbHelper.getWritableDatabase();
// enable Foreign Keys [http://www.sqlite.org/foreignkeys.html]
database.execSQL("PRAGMA foreign_keys = ON");
return database;
// method to close
public void closeDB() {
dbHelper.close();
SQLiteHelper.java
//automatic generated by https://www.pipiscrew.com/works/sqlite-manager-v1-0/
import java.io.File;
import java.io.InputStream;
import com.x.gr.R;
import android.content.Context;
import android.database.sqlite.SQLiteDatabase;
import android.database.sqlite.SQLiteOpenHelper;
import android.os.Environment;
public class SQLiteHelper extends SQLiteOpenHelper {
private Context c=null;
////////////////// AUTOMOTODETAILS //////////////////
public static final String TABLE_AUTOMOTODETAILS = "AUTOMOTODETAILS";
public static final String AUTOMOTODETAIL_ID = "AUTOMOTODETAIL_ID";
public static final String DATEREC = "DATEREC";
public static final String KM_COUNTER = "KM_COUNTER";
public static final String FIXES = "FIXES";
// public static final String COMMENT = "COMMENT";
////////////////// AUTOMOTOS //////////////////
public static final String TABLE_AUTOMOTOS = "AUTOMOTOS";
public static final String AUTOMOTO_ID = "AUTOMOTO_ID";
public static final String DESCRIPTION = "DESCRIPTION";
public static final String PLATE = "PLATE";
// public static final String COUNTRY_ID = "COUNTRY_ID";
public static final String AUTOMOTO_DATEREC = "AUTOMOTO_DATEREC";
////////////////// COUNTRIES //////////////////
public static final String TABLE_COUNTRIES = "COUNTRIES";
public static final String COUNTRY_NAME = "COUNTRY_NAME";
public static final String COUNTRY_sort_ORDER = "COUNTRY_sort_ORDER";
////////////////// SETTINGS //////////////////
public static final String TABLE_SETTINGS = "SETTINGS";
public static final String SETTING_ID = "SETTING_ID";
public static final String USERNAME = "USERNAME";
public static final String PASSWORD = "PASSWORD";
//public static final String DATABASE_FILE_PATH = Environment.getExternalStorageDirectory().toString();
private static final String DATABASE_NAME = "x.db";
private static final int DATABASE_VERSION = 1;
// Database creation sql statement
private static final String DATABASE_CREATE = "CREATE TABLE [AUTOMOTODETAILS] (" +
"automotodetail_id INTEGER PRIMARY KEY, " +
"daterec TEXT, " +
"km_counter TEXT, " +
"fixes TEXT, " +
"comment TEXT);CREATE TABLE [AUTOMOTOS] (" +
"automoto_id INTEGER PRIMARY KEY, " +
"description TEXT, " +
"plate TEXT, " +
"country_id INTEGER, " +
"comment TEXT, " +
"automoto_daterec TEXT, " +
"FOREIGN KEY(country_id) REFERENCES countries(country_id));CREATE TABLE [COUNTRIES] (" +
"country_id INTEGER PRIMARY KEY, " +
"country_name TEXT, " +
"country_sort_order INTEGER);CREATE TABLE [SETTINGS] (" +
"setting_id INTEGER PRIMARY KEY, " +
"username TEXT, " +
"password TEXT);";
public SQLiteHelper(Context context) {
// super(context, DATABASE_FILE_PATH
// + File.separator + DATABASE_NAME, null, DATABASE_VERSION);
//internal storage (can be viewed only when rooted)
//location : data/user/0/x.gr
super(context, DATABASE_NAME, null, DATABASE_VERSION);
c= context;
public void onCreate(SQLiteDatabase db) {
db.beginTransaction();
try {
String[] queries = DATABASE_CREATE.split(";");
for (String query : queries)
db.execSQL(query);
//Add predefined records to tables (TSQL already stored as resource file)
InputStream Stream = c.getResources().openRawResource(R.raw.countries);
String countries_predefined_sql = General.convertStreamToString(Stream);
queries = countries_predefined_sql.split(";");
db.execSQL(query);
db.setTransactionSuccessful();
} finally {
db.endTransaction();
public void onUpgrade(SQLiteDatabase db, int oldVersion, int newVersion) {
// db.execSQL("DROP TABLE IF EXISTS " + TABLE_COMMENTS);
// onCreate(db);
R.raw.countries
PRAGMA foreign_keys = OFF;
INSERT INTO "main"."countries" VALUES (1, 'Afghanistan', null);
INSERT INTO "main"."countries" VALUES (81, 'Greece', null);
CountriesDatasource.java
import java.util.ArrayList;
import java.util.List;
import android.content.ContentValues;
import android.database.Cursor;
public class CountriesDatasource {
private SQLiteDatabase database;
private static final String[] allColumns = { SQLiteHelper.COUNTRY_ID, SQLiteHelper.COUNTRY_NAME, SQLiteHelper.COUNTRY_sort_ORDER };
public CountriesDatasource(Context c) {
database = ((Dynomite) c.getApplicationContext()).getSQLiteInstance();
public Countries createCountries(Countries countries) {
ContentValues values = new ContentValues();
values.put(SQLiteHelper.COUNTRY_NAME, countries.getcountry_name());
values.put(SQLiteHelper.COUNTRY_sort_ORDER, countries.getcountry_sort_order());
long insertId = database.insert(SQLiteHelper.TABLE_COUNTRIES, null, values);
Cursor cursor = database.query(SQLiteHelper.TABLE_COUNTRIES, allColumns, SQLiteHelper.COUNTRY_ID + " = " + insertId, null, null, null, null);
cursor.moveToFirst();
Countries countriesRET = cursorToCountries(cursor);
cursor.close();
return countriesRET;
public int updateCountries(Countries countries) {
return database.update(SQLiteHelper.TABLE_COUNTRIES, values, SQLiteHelper.COUNTRY_ID + " = ?", new String[] { String.valueOf(countries.getcountry_id()) });
public void deleteCountries(long ID) {
database.delete(SQLiteHelper.TABLE_COUNTRIES, SQLiteHelper.COUNTRY_ID + " = " + ID, null);
public List<Countries> getAllCountriess() {
List<Countries> countriess = new ArrayList<Countries>();
Countries countries = null;
Cursor cursor = database.query(SQLiteHelper.TABLE_COUNTRIES, allColumns, null, null, null, null, null);
while (!cursor.isAfterLast()) {
countries = cursorToCountries(cursor);
countriess.add(countries);
cursor.moveToNext();
// Make sure to close the cursor
cursor.close();
return countriess;
private Countries cursorToCountries(Cursor cursor) {
Countries countries = new Countries();
countries.setcountry_id(cursor.getLong(0));
countries.setcountry_name(cursor.getString(1));
countries.setcountry_sort_order(cursor.getLong(2));
return countries;
public Countries getID(long ID) {
Cursor c = database.rawQuery("select country_id as [country_id],country_name as [country_name],country_sort_order as [country_sort_order] from COUNTRIES where COUNTRY_ID=" + ID, null);
c.moveToFirst();
return cursorToCountries(c);
public Cursor countriessCursor() {
Cursor c = database.rawQuery("select COUNTRY_ID as _id, country_name as [country_name],country_sort_order as [country_sort_order] from COUNTRIES", null);
// database.query("COUNTRIES",allColumns, null, null, null,null,null);
c.moveToFirst();
return c;
MainActivity.java
public class MainActivity extends Activity {
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_main);
CountriesDatasource x = new CountriesDatasource(MainActivity.this);
List<Countries> t = x.getAllCountriess();
for (Countries countries : t) {
Log.w(String.valueOf( countries.getcountry_id()), countries.getcountry_name());
Countries.java
public class Countries {
private long country_id;
private String country_name;
private long country_sort_order;
public Countries() {
public Countries(String country_name, long country_sort_order) {
this.country_name = country_name;
this.country_sort_order = country_sort_order;
public long getcountry_id() {
return country_id;
public void setcountry_id(long country_id) {
this.country_id = country_id;
public String getcountry_name() {
return country_name;
public void setcountry_name(String country_name) {
public long getcountry_sort_order() {
return country_sort_order;
public void setcountry_sort_order(long country_sort_order) {
