Excel - loop through and empty cells where needed
in the following code, compare the 3rd column on each row, if is the same as the previous one, then empty the cells needed.
Useful when export raw data by database when making a breakdown of records..
Sub Button1_Click()
    Application.ScreenUpdating = False
    Dim ws As Worksheet
    Dim r As Range
    Dim iRow As Long
    Set ws = ThisWorkbook.Worksheets("Export Worksheet")
    Set r = ws.Range("A1:K16376")
    Dim prevValue As String
    prevValue = "00"
    For iRow = 1 To r.Rows.Count
       If (r.Cells(iRow, 3) = prevValue) Then
        prevValue = r.Cells(iRow, 3)
        r.Cells(iRow, 1).Value = ""
        r.Cells(iRow, 2).Value = ""
        r.Cells(iRow, 3).Value = ""
        r.Cells(iRow, 4).Value = ""
        r.Cells(iRow, 5).Value = ""
        r.Cells(iRow, 6).Value = ""
        r.Cells(iRow, 9).Value = ""
        r.Cells(iRow, 10).Value = ""
        r.Cells(iRow, 11).Value = ""
       Else
       End If
    Next iRow
    Application.ScreenUpdating = True
End Sub
or for speed use an empty string array and pass it to a row range
Sub Button1_Click()
   Dim bl(6) As String
            ws.Range("A" & iRow & ":F" & iRow).Value = bl
            ws.Range("I" & iRow & ":K" & iRow).Value = bl
       Else
       End If
#vba
