the modal form somewhere hidden in html :
the JS code :
the PHP file called by form
<!-- NEW SUBCATEGORY MODAL [START] -->
<div class="modal fade bs-modal-lg" id="modaloSUBSECTOR" tabindex="-1" role="dialog" aria-labelledby="myModalLabel" aria-hidden="true">
<div class="modal-dialog modal-lg">
<div class="modal-content">
<div class="modal-header">
<button type="button" class="close" data-dismiss="modal" aria-hidden="true">
</button>
<h4 class="modal-title" id='lblTitle_oSUBSECTOR']New Sub Sector</h4>
<div class="modal-body">
<form id="formoSUBSECTOR" role="form" method="post" action="test.php">
<div class='form-group']
<label>Parent Sector :</label>
<select id="oSECTOR_description" name='oSECTOR_description' class='form-control' readonly>
</select>
<label>Sub Sector Name :</label>
<input id='oSUBSECTOR_name' name='oSUBSECTOR_name' class='form-control' placeholder='Sub Sector Name']
<div class="modal-footer">
<button id="bntCancel_oSUBSECTOR" type="button" class="btn btn-default" data-dismiss="modal">
cancel
</button>
<button id="bntSave_oSUBSECTOR" class="btn btn-primary" type="submit" name="submit">
save
</button>
</div><!-- End of Modal body -->
</div><!-- End of Modal content -->
</div><!-- End of Modal dialog -->
</div><!-- End of Modal -->
<!-- NEW SUBCATEGORY MODAL [END] -->
the JS code :
// MODAL FUNCTIONALITIES [START]
//when modal closed, hide the warning messages + reset
$('#modaloSUBSECTOR').on('hidden.bs.modal', function() {
//when close - clear elements
$('#formoSUBSECTOR').trigger("reset");
//clear validator error on form
validatorSUBSECTOR.resetForm();
//functionality when the modal already shown and its long, when reloaded scroll to top
$('#modaloSUBSECTOR').on('shown.bs.modal', function() {
$(this).animate({
scrollTop : 0
}, 'slow');
// MODAL FUNCTIONALITIES [END]
//jquery.validate.min.js
var validatorSUBSECTOR = $("#formoSUBSECTOR").validate({
rules : {
oSUBSECTOR_name : {
required : true,
minlength : 2,
maxlength : 100
oSECTOR_description : { greaterThanZero : true }
messages : {
oSECTOR_description : 'Required Field',
oSUBSECTOR_name : 'Required Field'
// MODAL SUBMIT aka save button
$('#formoSUBSECTOR').submit(function(e) {
e.preventDefault();
////////////////////////// validation
var form = $(this);
form.validate();
if (!form.valid())
return;
var postData = $(this).serializeArray();
var formURL = $(this).attr("action");
//close modal
$('#modaloSUBSECTOR').modal('toggle');
$.ajax(
url : formURL,
type: "POST",
data : postData,
success:function(data, textStatus, jqXHR)
if (data=="ok")
//update gui here
alert("ERROR");
error: function(jqXHR, textStatus, errorThrown)
alert("ERROR");
session_start();
if (!isset($_SESSION["x"])) {
header("Location: x.html");
exit ;
if(!isset($_POST['oSECTOR_description']) || !isset($_POST['oSUBSECTOR_name'])){
echo "error";
return;
//DB
require_once ('config.php');
$db = connect();
$sql = "INSERT INTO x (x, x) VALUES (:client_sector_sub_name, :client_sector_id)";
$stmt = $db->prepare($sql);
$stmt->bindValue(':client_sector_sub_name' , $_POST['oSUBSECTOR_name']);
$stmt->bindValue(':client_sector_id' , $_POST['oSECTOR_description']);
$stmt->execute();
$res = $stmt->rowCount();
if($res == 1)
echo "ok";
echo "error";
